How To Crop Your Photos and Recover 100% Resolution with Gigapixel AI
Sometimes you want to work with a portion of a photo, but "cropping in" reduces resolution. Gigapixel AI helps you crop images without compromising your pixel count.
It’s a great feeling to find the perfect image for your project, but what if you only want to work with a portion of the photo? Cropping into an image reduces the overall resolution which limits your use—especially for print, where every pixel counts. Let’s take a look at how Gigapixel AI can help you upsize your cropped photos by up to 600% and restore full-size resolution.
Crop and Resize with Gigapixel AI
Let’s start with a great image that would be made better with cropping. You can follow along yourself by downloading a totally free trial of Gigapixel AI, and downloading our free demo image.
The image we’re working with is 1920 x 1276 pixels, which is suitable for most uses but we want to crop tightly on the model’s face.
Launch the image in Gigapixel AI, and click on the crop tool to select your crop. Apply your selection. After cropping, our image is now only 484 x 294 pixels—not much to work with here! Let’s see how Gigapixel can improve this crop.
In the main Gigapixel AI interface, we see a preview of 4X upscaling, which gives us an output of 1936 x 1176 pixels. You’ll see that the compression artifacts are gone, the model’s skin is smooth, and the details are sharp. But can we go even further?
We bump up our photo enlargement to 6X, or 600% larger than the cropped resolution.
This gives us an output of 2904 x 1764 pixels — larger than our original uncropped image — and yet the output is still silky smooth with sharp detail in the right places.
Gigapixel AI proves yet again to be an incredible image upscaling tool. But how does it compare to Photoshop?
Gigapixel AI vs Photoshop
 Let’s see whether Gigapixel can beat Photoshop, using the latest 2021 edition of Photoshop and its best image enlargement mode.
Using the same image and crop, we attempted 600% image upscaling in Photoshop 2021 using the Bicubic Smoother (enlargement) resampling mode.
The upscaling results in Photoshop were completely underwhelming. Compression artifacts are everywhere, and there is a lack of detail across the entire image.
A side-by-side comparison says it all. Gigapixel drastically outperforms Photoshop even up to 6X image upscaling.
Unlike older image editing algorithms, Gigapixel uses machine-learning technology to analyze your photo alongside millions of images to intelligently calculate the best output — this is why the results continue to shock and impress photographers all over the world. Try it totally free and see for yourself!
5 thoughts on “How To Crop Your Photos and Recover 100% Resolution with Gigapixel AI
  1. What could I expect from a photo (dpi 72 or 96) that I want to enlarge to something like 11×14 and at 300dpi? No cropping involved; just a straight enlargement in size (inches or pixels) and dpi (to 300)?
  2. (I currently use AI sharpen) It seems to me that there is significant overlap between AI sharpen and Gigapixel. Can Gigapixel replace AI sharpen? Can one use Gigapixel on the full uncropped photo? Have you performed similar tests?
    Thank you
  3. Gigapixel AI is one of the best tools Topaz has come out with. It’s amazing how much improved an image is, compared to the original, after running it through Gigapixel AI! I use it almost daily!
  4. What if I already cropped in PS? How do I get a great image without artifacts then? I usually use Gigapixel after PS.
  5. This is totally amazing.
Leave a Reply
Your email address will not be published. Required fields are marked *
You'll receive your trial download and account through email.
Johnnie Lamptey
Photographer
G-icon-png
Topaz Bundle
Save: $149.99
Total: $1349.91
