Introducing Topaz Studio
What is Topaz Studio?
Topaz Studio is a fast, flexible, powerful creative toolbox and it’s the next level image editor for photographers. Topaz Studio gives you lightning fast results with Topaz’s exclusive image processing technology, in an intuitive, affordable, easy to use application.
Topaz Studio a simple to use editing platform with Topaz Labs’ acclaimed photo enhancement technology. It works as both a standalone editor, a plugin within Lightroom and Photoshop, and a host application for other Topaz plugins which means it works exactly how you want it to. Now there’s no more cumbersome workflows that require you to open multiple plugins to achieve your look!
“This is all your Topaz products wrapped into one program.”
Topaz Studio is an easy to use editing solution built with the photographer in mind. This all new editing platform features professionally created 1-click effects, 24 flexible drag and drop Adjustments, and powerful image processing.
And We’re Giving it Away! Yep, you read that right. You’ll get complete freedom to use Topaz Studio as a plugin, a host editor for all Topaz Labs existing products, 10 free adjustments, comprehensive masking, opacity slider, and blending modes functionality all for free.
Download Now
[ucaddon_uc_icon_hover_effect_button text=”Macintosh” icon=”fa fa-apple” link=”http://d2xkriaa67cpt4.cloudfront.net/topazstudio_online_installer.dmg” background_color=”#0f9af8″ uc_fonts_data=”JTdCJTdE”]
[ucaddon_uc_icon_hover_effect_button text=”Windows” icon=”fa fa-windows” link=”http://d2xkriaa67cpt4.cloudfront.net/topazstudio_online_installer.exe” background_color=”#0f9af8″ uc_fonts_data=”JTdCJTdE”]
Working in Topaz Studio
Working in Topaz Studio is easy! Topaz Studio is set up with the photographer in mind. Whether you’re just getting started with photography or a tried and true professional, Topaz Studio has exactly what you need. With an ever growing library of expertly crafted pre-made effects to professionally crafted assets to artistic and technical tools alike, Topaz Studio is the perfect photographer toolbox, no matter what level of expertise!
All About the Workspace
Topaz Studio Interface
Topaz Studio features an easy to use Toolbar, a fast and fun Effect Panel with search buttons and features, the workspace, an Image Browser, the Scopes panel, and the Adjustment Panel, complete with Adjustment Buttons.
1. Main Toolbar
Topaz Studio Main Toolbar
The Main Toolbar gives you options to open and save images, an option for comparing the before image and after image, zooming, and split views. You can also click the Open Button to open additional images and save images with the Save Button and Save As Button.
Saving Your Image
Topaz Studio Announcement
Save or Save As Images. Save edited images as PNG, JPG, or TIFF files with easy to locate buttons in the Main Toolbar, by using shortcut keys (Command S or Command Shift S), or by going to Menu > File > Save or Save As.
2. Effect Panel
Topaz Studio Effect Panel
When you first load an image, you’ll see Featured Effects in the Effect Panel. Here you can search for effects by typing an author name, an effect name, tags, or categories.
View Options
Click the Grid Button to see more effects at a time. Once in Grid View, click the List Button to see a single column list of effects.
3. Effect Buttons
Topaz Studio Effects Buttons
The Effect Buttons give you access to a list of Categories and Tags to search for effects quickly and easily. Click the More Button to see a full list of all available categories and tags.
4. Canvas
Topaz Studio Canvas
The Canvas area is where your active image will be displayed. Easily change the view options of the Canvas with the Main Toolbar, found in section 1 above.
5. Image Browser
Topaz Studio Image Browser
Use the Image Browser to view and adjust various edits of an image side by side or work on several images at once.
Select Show Options to access the menu.
Apply – Apply the adjustments to the image and use the result to start a new project.
Duplicate – Duplicate an entire project and then add it as a new project.
Copy / Paste – Copy the entire adjustment stack and paste them onto a different project.
6. The Scopes Panel
Topaz Studio Scopes Panel
At the top right of the application is the Scopes Panel that features 4 separate views. The first allows you to view the Histogram of the image. The second displays the Hue, Saturation, and Luminance of the image, while the third button displays the amount of image Details. Finally, the fourth button helps you navigate your image while zoomed in.
7. The Adjustment Panel
Topaz Studio Adjustment Panel
The Adjustment Panel is where you can modify effects or create your own. It gives you control over the large range of tools and adjustments located in the Adjustment Buttons. The Adjustment Buttons features some of the most commonly used adjustments, and you can see all available adjustments by clicking the “More” button at the bottom of the list.
Saving Your Custom Effect
Save and Share Your Effects. Save your new effect by clicking the Save button and share your creation with others by selecting ‘Yes’ in the Public field. Your effect will be shared to the entire Topaz Community instantly!
8. Adjustment Buttons
Topaz Studio Adjustment Buttons
The Adjustment Buttons gives you access to a list of commonly used Adjustments like Crop, Lens Correction, Basic Adjustment, and more. Click the More Button to see a full list of all available Adjustments.
Tools
Topaz Studio Announcement - Tools
We’ve also included a tools section. You’ll find lens correction, global masking (with 5 styles and 4 different tools to customize the overall effect), and crop and rotate. Everything is located in a simple to use toolbar with easy-to-use sliders and functionality.
Change Up the Workspace
Customize your workspace windows with just the click of a button. The Effect Panel, Scopes Panel, Adjustment Panel, and Image Browser can each be collapsed by clicking the arrow on the bar on the inside edge of the panel. The Effect Buttons and Adjustment Buttons can also be collapsed and expanded by clicking at the top of the toolbar.
Wait… What are Adjustments?
Topaz Studio Announcement - Adjustment Stack
Adjustments are the core of Topaz Studio, they are built with very focused functionality in mind. Adjustments may be used independently or combined to create extremely unique looks and custom effects. Currently, there are 24 Adjustments available covering everything from simple Film Grain, to advanced color control with Color Theme. Adjustments are grouped according to complexity, with Common Adjustments appearing at the top, Advanced Adjustments in the next section, Artistic Effect Adjustments below that, and Compositing Adjustments appearing last.
While many of these adjustments are free, some must be purchased to allow you to fully customize the sliders they contain. However, each paid adjustment also comes with a 30 day free trial. To activate the trial, just click the Try Pro Button to activate it or use the Buy Now Button to be taken to the Topaz Studio website to complete your purchase. Whether you purchase adjustments or not, you’ll always have access to Blending Modes, Masking, Opacity, and the included Adjustment Level Presets… all for free. You can always use effects that contain paid adjustments you don’t own as well.
With Topaz Studio Adjustments, you can add, customize, mask, rearrange, and delete Adjustments until you have exactly the look you want.
Free Adjustments: Basic Adjustment, Brightness Contrast, Blurs, Color Overlay, Dual Tone, Film Grain, Image Layer, Posterize, Tone Curves, and Vignette.
Pro Adjustments:  Abstraction, Black & White, Bloom, Color Theme, DeHaze,  Edge Exposure, Focal Blur, HSL Color Tuning, Precision Contrast, Reduce Noise, Radiance, Sharpen, Smudge, and Texture.
To learn about the Adjustments, check out our short videos on YouTube.
Versatile Masking
Topaz Studio Announcement - Masking
The Topaz Studio Integrated Masking is unlike anything you have seen before. We have included 5 masking types: Brush, Spot, Gradient, Color, and Luminosity, as well as a mask adjustments panel and an option to invert or completely reset your mask. Our brush masking includes intuitive, content-aware technology that was developed in house. I’ve gotten the chance to play with it quite a bit –  it’s awesome and a complete time saver to say the least. Not only are the new masking features amazing, but you can now combine masking types. After making adjustment with one type of mask, click apply or switch to another mask type and build upon that mask. It’s never been so easy!
Technical Information
All you need is a Topaz Studio account to access your software. Existing users use their same login info, while new users can create an account. You will only have to have an internet connection every 60 days to authenticate your account.
Compatibility:
Photoshop CS4+, Photoshop CC, Photoshop Elements 12+, Paintshop Pro X 6+, Serif PhotoPlus X5+, Lightroom 4+, Lightroom CC, and photoFXlab
*Not compatible with Fusion Express
System Requirements:
Mac OSX 10.9+
Windows 7/8/10 x 64bit + OpenGL 3.3
RAM: ≥4GB
GPU VRAM: ≥1GB
*Does not support Windows 32bit
Download Now
It’s Easy to Update
Topaz Studio is designed to be easy to update, by prompting you when updates are available and allowing you to update your application without having to go through an entirely new installation through the new update manager application included with Topaz Studio.
That’s all for now but keep an eye out for additional updates and new features in the application, online on our social media sites and always on the Topaz Studio Website at topazlabs.com!
About Jodi L. Robbins
Topaz Labs - Jodi L. Robbins
Jodi is currently the Art Director of Topaz Labs. She has been an artist and photographer for over 15 years, starting with black and white film photography and alternative processing. After completing her BFA in Studio Art from Southern Methodist University and her Masters in Photography from Savannah College of Art and Design, she worked in product photography for companies such as Heritage Auctions, Neiman Marcus, and the Dallas Cowboys.
Share on facebook
Share on twitter
Share on linkedin
Share on email
Related Posts
131 thoughts on “Introducing Topaz Studio
  1. Saving layers in photFXlab vs Studio: If I understand correctly, photoFXlab had a pflx format that worked with the Save As option. Studio loses that option and it is replaced by the ability to save an effect stack in Studios file space and in the community space. Am I right?
    1. Hi Martin! This is a feature request that is being looked at by development. The preset/effect saving is not the same thing. You may save effects within the program but you may not saved layered files at this time. I hope this answers your question.
  2. I’m an old guy and been using Topaz for a long time but I’m confused. Misunderstanding probably. Seems like one place says the new thing (Topaz) is $70 and another place it is Free.
    Please explain. Thanks Tom Garret tpgarrett77@suddenlink.net
    1. Hi Tom! Both of these statements are true but let me explain in detail. Topaz Studio is free to use. You may download the program, use all the effects, use editing tools, presets, and 10 free Adjustments (such as Basic Adjustment, Vignette, and Image Layer). If you would like to upgrade to the Pro Pack, you may do so for a very limited time for the discounted price of $70. Buying the Pro Pack will give you complete access to all 14 additional Adjustments. I hope this helps clarify!
    2. Raw images with .ARW extensions are opening with about 2 to 3 f stops under exposed. Additionally, some tif files do not open.
      I noticed that the shadow slider doesn’t control the shadow as accurately as Adobe ACR. Topaz slider seems to adjust the whole image as opposed to just the shadows.
      1. Ronace,
        Thats a good catch, Can you submit a ticket here? We’ll work with you to figure out the issue. https://help.topazlabs.com/hc/en-us/requests/new
  3. A couple of questions. I have all of the Topaz app. Is the pro pac necessary? I see all of my apps are listed. Secondly, it looks like FXLaps is not necessary because it looks redundant now that Studio.
    1. Hi Bob! Topaz Studio is completely free to use without upgrading to the Pro Pack. You can use all of your Topaz Plugins with Topaz Studio since it runs as a host editor. Topaz Studio is also built with newer, faster technology. You may enjoy working with it instead of Photo FX Labs but you may certainly continue to use your old workflow. It’s completely up to you!
      1. My question is similar. What happens to the topaz software I already have…how do i use it? What happens to PhotoFX lab? How does it differ from Studio?
        1. You can use all of your Topaz Plugins with Topaz Studio since it runs as a host editor or you can stick with your current workflow. There are no changes to your Topaz Plugins.
          1. Yes, but are the plugins still useful? It seems they are already built into the studio.
  4. Are there tutorials available on how to use the product?
    1. Hi! We are definitely working on more tutorials and content to help users like yourself learn more about the program and Adjustments. Stay tuned for more learning materials like blog articles and videos!
  5. Can you browse images within Topaz Studio?
    1. Hi Teresa! You can use the Image Browser (located at the bottom of the workspace) to see multiple open images. I hope this answers your question.
  6. Hello,
    I have been a long time user over the years of Topaz Labs products and plugins. I was thrilled to learn of the introduction of Topaz Studio and have purchased the Pro-pack adjustments to compliment the program. My comment is, I would like to see some extensive YOUTUBE tutorials of the use of the program and adjustment sliders visually showing results of an actual editing sequence presentation of image post-processing. This has been done in the past with much of Topaz original products and the learning experience has been a tremendous benefit. I have seen the quick one-minute introduction youtube videos showing Studio adjustments and brief usage guide, but would greatly appreciate a more extensive visual and explanatory tutorial showing the sliders in action and results they produce.Studio looks to be a tremendous artistic and creative post-processing tool and once again Topaz has produced a winner!
    regards,
    John Kunze
    West Bend, Wisconsin
    1. Hi John! Thanks for being a loyal Topaz user. We are definitely working on more tutorials and content to help users like yourself learn more about the program and Adjustments. We appreciate the kind words! Stay tuned for more learning materials!
      If anyone else would like to see the introduction videos, you may do so here: https://www.youtube.com/channel/UC7hSvaP2LDSLlnmctnyPjzw
  7. Really wish I could use it but sadly like many of your recent apps my computer will not support it due to lack of OpenGL compatibility.
    1. Hi Debra! We’re so sorry to hear about the compatibility issue. Topaz Studio will remain a free program (with pro upgrades) so it’s ready to download whenever you are!
  8. I’ll be going out of town tomorrow and will be gone into June. I’d like to know more about the ingredients of the Pro Pack. I’m not sure what I’m buying if I purchase it. All my old Topaz plug-ins work with the Studio, am I correct? (I think I have them all.) What do the things in this pack do that they don”t?
    If I decide to buy the Pro Pack, I definitely want to get this bargain price. But I’m an old retired character living on limited income, so must be sure it’s something I’ll use. Can you provide more information than just the sample photos shown on the web page?
    Thanks!
    1. Hi Leon! That’s definitely understandable. Topaz Studio is a free editor that will host all your Topaz Plugins. Buying the Pro Pack will allow you to have access to all the sliders in 14 different adjustments. You can always use the effects, 10 free adjustments, adjustment level presets, for free and there’s a 30 day free trial of each adjustment if you’d like to try before you buy! You can read all about the Pro Adjustments on their pages, which can be found here: https://topazlabs.com/
      1. I’m missing something. I’ve been looking at the pages on the web site but haven’t seen anything about the sliders, etc. I confess that I didn’t play with the beta release as much as I wanted (ran into problems when saving as jpeg and tiff files – big color changes with jpegs and PS & LR couldn’t read the tiff files though ON1 RAW could). More experimentation there might have helped, sigh. I don’t expect to have a chance to play with the final program before my departure tomorrow and won’t have access to my computer for 10+ days. 🙁 Life is sometimes complicated and confusing. Guess that’s what makes it interesting. 😉
      2. Hey Jodi, I think I found the page you referred to. I’d been looking at the info on the page for the discount on the Pro Pack and somehow missed the page that had the videos with info on the individual modules. Now I’ve got to make an informed decision, and that’s never easy. 🙂 Ah, such is life.
        1. Hi Leon! Let us know if you have any questions or need any additional help. Have a great day!
  9. “It works as both a standalone editor, a plugin within Lightroom and Photoshop, and a host application for other Topaz plugins…” Topaz says near the top of this page. And indeed I can access it from PS (CC) and as a stand-alone (from Task Bar), but still don’t see it (v. 1.0.1) anywhere in LR (CC). I THOUGHT I had seen v. 0.8 on the Develop|Photo|Edit In… menu, where all my other Topaz plug-ins are located. Also don’t see it on Develop|File|Plug-in Manager… [searched for .lrplugin file from Topaz on my hard drive] nor of course therefore on Develop|File|Plug-in Extras… where I DO see OnOne’s RAW 2017, which is also a stand-alone (and it’s component modules are shown in the same menu as my Topaz plug-ins).
    Since I use LR (CC) as my images browser and start my editing from that platform, I would like to access Topaz Studio from that host, as well as PS (CC). You seem to say that I should be able to, so: how?
    [on pc, PS and LR CC current, LR opened after downloading latest TS version]
    1. Diana,
    2. No problem in Lightroom CC…it’s found under Photo>Edit In>Topaz Studio…
  10. I’ve purchased your product, Topaz Studio. Long time user, so kinda know my way around, but darn where is Studio? After I open a photo, go to to Topaz and all I see are the things I already have. Please a little help to get me back on track. Thanks
    1. Hi Geraldine! Thanks so much for the continued support! You can open Topaz Studio as a standalone or as a plugin. You can either start with 1-click effects (in the left column) or start editing from scratch (use the adjustment buttons on the ride side and be sure to click MORE to see all 24 adjustments). If you are having technical difficulties (like using Topaz Studio as a plugin in PS), please submit a help ticket so we can investigate the issue and give you a hand: help.topazlabs.com
  11. I currently own all your Topaz plugins. Are you going to continue to update and make improvements to the products i currently own or are you just going to be focusing on your new products? Why do i only have until 5/30 to get the discount? I just got the email today 5/25 that you even had this new program. As a customer who has spent hundreds of dollars on your products over the years i would of thought you would be offering me as well as all existing customers of your entire suite of products the discounted price for an extended length of time as On1 software did for those who wanted to update to Photo Raw 2017.
    1. Good morning! Thanks for the support throughout the years! We are definitely going to continue updating past programs. The special introductory price for Topaz Studio is actually a discount on top of a discount, especially for loyal customers such as yourself. All 14 Pro Adjustments would normally be $274.86 and are discounted down to $137.50 if you buy them all. The entire Pro Pack will be on sale for $99 but since you (and a lot of other people!) are so loyal, we slashed it even further down to $70! If this is still too much, you can always use Topaz Studio for free. You’ll have access to the 1-click effects, editing tools, and 10 free adjustments even if you never spend a dime. Have a great day!
  12. I can log in to the web site but the application login fails every time, (on 2 pcs). So I cannot access the program unless I open preferences, then cancel preferences, then I can access the program. However some strange things happen. It is slow and when changing from a sample on the right to another it gives a rotating circle to show that it is doing it but it just circles for ever. Same thing when I pressed get pro on one of the adjustment sections. Did I mention it is slow, some actions are so slow I can could do many actions in ACDSEE while waiting.. One PC is 16GB ram with A10 processor the other a new R7 1700 with 16GB 3200 ram so there should be no problems with either. I suspect the log in not working is the cause of problems.
    1. Oh BTW I have most of the Topaz plugins and they all work well and as I expect them to work. So I am aware of whet to expect from Topaz.
      1. I have all of the Topaz plug-ins and they do indeed all open…In Topaz Studio, go to Plug-Ins at the top of the page and all of the Plug-Ins will show there and then pick one…
    2. Hello! Thank you so incredibly much for this valuable feedback! I’d like you to open a support ticket so that we may investigate the issues you are describing: help.topazlabs.com
  13. HI, Jodi,
    You wrote, “You may save effects within the program but you may not save layered files at this time.” That’s a lot of editing work that can’t be tweaked after the fact layer-wise! It sounds like Studio has a ton of wonderful features to play with. The ideal would be the ability to save as a layered doc so a specific layer can be easily altered or deleted at any point along the way if need be. I guess the next step would be to find a way to save stacked layers with Studio? I hope the Development team can do it at some point. Sounds like a winner to me! Topaz plug-ins are fantastic!
    1. Hi! Yes, you read that right: You may edit and change the Adjustment Stack as much as you like before you save and commit. I highly suggest you save your effect for future use, too. You can always apply an Effect again at a later time and then make changes to the Adjustment Stack. We’ll definitely look into finding a way to save stacked layers with Studio. Great idea! I hope you’re having fun with Topaz Studio. Stay tuned for updates as it’s only going to get better!
  14. I have been a user of Topaz products for five years, I am totally committed to using them and the opportunity to get Topaz Studio is one I have jumped at. Having downloaded it though I am at a loss to see how to pay the $70 or so. Could you please help make the payment.
    1. Hi Barry! If you head over to https://topazlabs.com/product/adjustment-pro-pack/ and add it to your cart you can checkout. Remember to use your coupon code at checkout! If you need additional assistance, please fill out a support ticket at help.topazlabs.com.
  15. I purchased Topaz Sudio on 4-4-17. It shows V0.8.0 I can’t find any place to update. John Barclay is offering a $99 pre release for Topaz Studio Pro. Is this what I have or do I need to order that to?
    1. Hello! You can always open up Topaz Studio and then go to the Menu and select Help > Check for Updates. Topaz Studio will check for updates and install them!
      If you would like unlimited access to all 24 Adjustments and you have not previously purchased anything within Topaz Studio, the John Barclay deal is a great way to get all 24 Adjustments at a great price!
  16. I’m familiar w/ several of the previous Topaz plug-ins & have used them thru Photoshop for some time now. I’ve been playing w/ Studio for only a few hours now & when I click on ‘save’ or ‘save as’ to save a revised photo, the photo is saved as the original image. However when I click the photo & open it, it opens as the revised photo. What do I have to do to get the revised photo to show in thumbnail form?
    1. Hi Glen! Thanks so much for the feedback! We were made aware that the thumbnails on Macs were not showing the edited image. Our developers are working on fixing that. You should see an update soon. Sorry about any inconvenience right now!
  17. Can the ProPack be used separately with LR, Elements, Photoshop, etc. or is it used exclusively with Topaz Studio?
    1. Hi Robert! Great question. The Adjustments have to be used within Topaz Studio. However, you may launch Topaz Studio as a plugin through Lightroom and/or Photoshop.
  18. So I purchased the pro pack thru your presale email link. How do I get the pro adj. to show up in Topaz Studio? Thanks.
    1. Hi Robert! Please try logging out and logging back in to Topaz Studio to reset your account. If that does not work, please open a support ticket: help.topazlabs.com.
  19. hi, I am a loyal topaz user for years. A lot of my work include Topaz Simplify to give it that special artsy look. when i now acqire TopazLabs, what happens to my other, older programs, eg like simplify?, does it wo rk as an plug-in to @lets say ps Cc 2015 or perhaps On1 RAW??
    or do i hav e to eliminate these older proprams? Knowing tht quality of Topaz programs,
    can I easily change between ps, on1 raw and save the work where i want. Can i continue working with Simplify as i did sofar?
    i am qite thrilled by Topaz Quality so far. I hope and assume it continuous in the new topazlabs.
    As i learned of the new project rather late, can i g et en extension of e couple of days for the new project?
    Thanks for clearing some incertainties and helping me!!
    GianPeider Anderhub h.anderhub @gmail.com
    1. Hello! You may continue to use Simplify as you have in the past. You may also use Simplify (and all other Topaz Plugins) as plugins within Topaz Studio, free of any charge!
  20. I am also confused. How much for Topaz Studio and Pro Pack for “loyal, exsisting customer / user”
    Is there a human voice I can talk to order, number?
    1. Hi Jeff! Topaz Studio is absolutely free to use. If you’d like to unlock all the professional adjustments, you can add the Pro Pack to your order for the special introductory price.
      We do not offer phone support but if you ever need assistance we are happy to help! Just fill out a ticket here: help.topazlabs.com
  21. HI, Jodi,
    Will I still be able to access my current Topaz modules from PSE (14) as a plug in, or do I have to (somehow) have an account into the Studio?
    Thanks, Alice
    1. Hi Alice! You can still access your Topaz Labs Plugins as you always have! You can start using Topaz Studio if you like but there’s no need to change your workflow.
  22. UPDATE: Ok I downloaded V1.0.2 and it did overwrite the V8.01 however it does not appear to take the serial number sent with original purchase, correct date is 4-12-17 which was the Topaz Photography Collection with all 17 programs. Then the question is the Adjustment Pro pack the 17th program and is it the same as Studio Pro that John Barclay is offering a pre release price on?
    1. Hi Gary. Please keep in mind that Topaz Studio (and the Pro Pack) is a new program and does not fall under the Topaz Labs Complete Collection (Plugins). Topaz Studio does not take a license key. It seems like you have a lot of questions so it might be beneficial for you to open a support ticket so we can get you taken care of.
  23. after reading comments, I am confused if I should get this or not. I understand I have access to some of the programs for free. (is this a limited time offer or will it always be free? ) What exactly do you get for the pro package. I have Adjust and textures, star, B&W,clarity. Is this program different from what I have already purchased?
    also the other programs i bought ,i can access them through lightroom by going to Edit in and going to my drop down Filter menu. This program does not show up on that list, onlt on my desk top. Why?
    1. Hello Lea! You are correct, Topaz Studio is free (and always will be) along with 10 free Adjustments. You can also access your Topaz Labs plugins within Topaz Studio for free. The Adjustments that are new in Topaz Studio are similar but have better technology, faster results, and a wider range of possibilities. Upgrading is completely up to you. You can always test out Adjustments for 30 days before you buy as well. Topaz Studio runs as a plugin with LR and PS. If you are experiencing any technical difficulties, please open a support ticket so that we can have a look at what’s going on and help you out!
  24. I am conflicted. I think I own all the Topaz plugins, so I clearly value your products, but I am not sure where this fits into the photography ecosystem. Is it supposed to replace Lightroom or Aperture (yes, I still use Aperture!) or Photoshop? Is it supposed to replace PhotoFXLab, which I dont think I ever used? As for the pro or not decision, I have not found the marketing materials that would persuade me one way or the other.
    On top of all that, and I am sure you are going to ask me to open a ticket for this, but I tried to start a trial for the Pro Effects – clicking on the Try Pro in the HSL Color Tuning tool, and it basically is spinning forever and my computer fan is on all the time. The program is NOT locked up, but something weird is happening. Another problem – I tried to launch Clarity, and it worked, but the image that opened up was either not there or was completely black.
    1. I was wrong. It did eventually lock up the program.
    2. Hello Doug!
      Thanks for being a loyal Topaz customer! You’ve asked a super valid question. Topaz Studio is designed to be a free editor that offers inspiration with 1-click effects, super powerful Adjustments, and fast processing. It’s the perfect solution for someone looking for an all in one photo editor and it’s also perfect for someone looking for a good deal to keep themselves on budget. You can read all about the adjustments on the website at topazlabs.com to see if it’s right for you and your workflow.
      …and unfortunately you are correct. We’ll definitely want you to open a support ticket for this concern.
      Hope this helps!
  25. Hi Jodi,
    We’ve bought everything else Topaz and would like to buy Studio Pro whilst it is available for $70.00.
    We can only see it being available for $137.50.
    Is there a coupon we should have?
    (we may have accidentally deleted an email or two)
    Regards Kym and Heather
    1. Hi Kym and Heather! Yes, there is a coupon code you should enter. It is PRESALE. Be sure to use it today though!
  26. is the topaz studio free for a limited time? Or will it always be available for free? Is the pro package part of the download? I cannot seem to find where I can download a trial offer of the pro package. I too am disappointed that the discount is only for a few days. I am working and do not have time to play with it and decide if I should purchase. Can the discount be extended?
    1. Hi Lea! Topaz Studio will always be free! You can use the program, the tools, 1-click effects, and 10 Adjustments for free forever. You can add a Pro Adjustment and select Try Pro for a free 30 day trial.
  27. I live in Canada. I have used most of your products for a number of years. You sent me an email, offering me a pre-launch discount. I took you up on your offer. When I chose to pay with PayPal, an online form was presented to me asking to authorize a payment to you of $70 USD, or just under $100 CAD. I was not charged that amount, but MUCH more, a total of $137.50 USD. Why was the discount offered not honoured, and how did you manage to fool PayPal into sending you an amount I did not authorize? How many other loyal customers are being charged more than your discounted price?
    1. Hello, and thank you for voicing this concern with us here at Topaz Labs. Our coupon code was valid but did not auto apply to the cart when customers such as yourself checked out. We take this very seriously and would like to offer you a refund as quickly as possible. If you haven’t already, please submit a support ticket at help.topazlabs.com so that we may issue the refund as soon as possible.
  28. It gets worse. I’ve been charged $137.50 USD, instead of $70 USD, and the program won’t let me us the software because I need to log into my account. Guess what? It tells me my password and email don’t match. Funny – they work when I log into my account at Topaz Labs, just not for the software that I as forced to pay far more than the discount…
    1. Hello again. Your Topaz Studio account is different than your Topaz Labs account. We want to help you sort this out as quickly as possible but since there is sensitive information (like emails and passwords) I suggest submitting a ticket so we can fix this for you.
  29. I can’t log into Topaz Studio with my Topaz Labs user name and password. Does this mean I need to create a separate username and password for Topaz Studio?
    1. Hi Gerald! You are correct! You will need an account for Topaz Studio because it is different than Topaz Labs Plugins.
  30. Will Topaz run under Affinity Photo?
    1. Hi David! Here is a list of the current compatible programs: Photoshop CS4+, Photoshop CC, Photoshop Elements 12+, Paintshop Pro X 6+, Serif PhotoPlus X5+, Lightroom 4+, Lightroom CC, and photoFXlab.
  31. For years I own several Topas programms as Plug-in to CC2017. Where does Studio come in? Is it a replacement for the older programms. e.g. Simplify, which I use often, is it replaced by Stuidio or do i still use it. I am a bit confused. Why pay 70 US when I have already top programms from Topaz? An hwen my main work is done in On1Raw and PS CC?
    Could you explain please? Thankyou!
    GianPeider
    1. Hello! Thanks so much for being a loyal Topaz customer! Topaz Studio is not a replacement for your plugins. You can use Topaz Studio for free (all the tools and 10 Adjustments) or upgrade to the Pro Pack to unlock all the tools. But, you can also keep your workflow that you already have with our plugins and a host editor (like PS). The main goal of Topaz Studio is to offer a free editor that is powerful and fast to users like you!
  32. So, does having Studio and the Pro Pack negate the need for Topaz Plugins?
    Is the built-in masking the same as Topaz ReMask?
    Does Pro Adjustment Precision Contrast replace Clarity?
    Pro Adjustment Black & White vs. Topaz B&W Effects? Pro Adjustment Reduce Noise vs. Topaz DeNoise?
    Are all my Topaz plugins that I’ve invested in now obsolete?
    1. Hi Ray! Those are great questions. Having Topaz Studio doesn’t negate needing Plugins but it does provide a host environment for running your plugins (so you no longer need LR pr PS). Masking is very different… there are 5 styles to choose from now (Spot, Gradient, Luminosity, Brush, and Color) and you can use them at the effect level or adjustment level. Precision Contrast is similar to Clarity but Precision Contrast is faster results while Clarity has more premade effects and styles. You’re Topaz Plugins are NOT obsolete. You can continue to use your plugins as you do now, with Topaz Studio, or combine them with Adjustments in Topaz Studio.
  33. Hello, I own most of the Topaz products. I don’t quite understand what is being added with the Studio? As I work with photoshop files (.psd) I would have to do it as a plug-in. So, what’s the advantage to this for me?
    1. Hi Leoni! You can always stay with your current workflow but Topaz Studio does have a lot to offer. It’s a standalone/host editor so you can use all your Topaz Labs plugins in one place, without any fees or subscriptions. It also has a lot of power. A LOT. There’s new processing that makes changes happen faster, a wider range of possibilities, and all new technology. Your workflow is completely up to you. You can always try Topaz Studio for free to see what you think. If you like the way your plugins work with a host (like PS) then there’s no need to change. Hope this answers your questions!
  34. Hi, I have the Topaz Adjust plugin. Is that usable in Studio, or is it a separate product? Thanks,
    1. Hi Nicolas! While Topaz Studio is a new, separate program you can use Topaz Adjust in Topaz Studio. Simply go to the menu and select Plug-ins, then Adjust. Hope this helps!
  35. I am the kind who likes to have a User Guide because I learn best by reading then doing. Is there a guide available yet? If so, where can I download?
    1. Hi Joseph! We do not have a User Guide. Great idea to have one!
    2. I have all of the Topaz plug-ins and they do indeed all open…In Topaz Studio, go to Plug-Ins at the top of the page and all of the Plug-Ins will show there and then pick one…
  36. I can’t see how to download the upgrade/Presale
    1. Hi Peter! You can head over to the store page on the website and check out to add the Pro Pack to Topaz Studio. Be sure to use the coupon code for a discount! presaletsext
  37. Hi Jody,
    I have a question regarding the Pro Adjustments.
    Does the Pro Adjustments replace their respective Topaz Plug-ins?
    For example, does the Reduce Noise Pro Adjustment replace (“kind of”) the DeNoise plug-in?
    Thanks,
    1. Hi Michel! That’s a really great question! The Adjustments may be similar but the Adjustments have all new technology and a faster processing speed. You can always use your Topaz Plugins with Topaz Studio but be sure to give the new Adjustments a try to see what you think!
  38. Hi Jodi,
    Perhaps you can help me, I tried to purchase the Pro Adjustments Package yesterday 29th May at the members price of $70 but the coupon shows as expired.
    I have had no reply from Sales yet and it is now 30th May here in Australia.
    Sorry to intrude like this but I noticed that when someone has experienced a technical problem, help arrives:)
    Regards,
    Neil
    1. Hi Neil! Thanks for reaching out and we’d be happy to help you out! Give this coupon a try: presaletsext. Have a great day!
  39. Hi,
    saving a file as *.jpg or *.tif will end with different icc-profiles embedded in the file (also different to the profile the file had when it was opened).
    What’s that. Will there be a version in the future having a really working colormanagment (where I can decide which icc-profile to embed)?
    Thanks for a reply.
    1. Hi Axel! Currently we save .jpg with sRGB and .tiff with prophoto. We will have a preference dialog with limited options (choose sRGB or prophoto for saving as tif). Unfortunately, that is all the information I have at this time!!
  40. Hi,
    I have recently purchased all of your plug ins, and now downloaded Studio along and purchased the Pro Adjustments, however it states that I can use the trial for the Pro Adjustments….so how do I get the Pro Adjustments into my ‘Studio’ that I purchased, I am logged in and also have Sync adjustments, if you can please advise, I have seen that others are having the same issue.
    thanks
    Jackie
    1. Hi Jackie! I would try logging out and logging back in. If that does not reset Topaz Studio for you, please submit a ticket so that we can look further into this! help.topazlabs.com
  41. I’ve been trying to buy the propack with the discount code but it won’t allow me. I’ve emailed several times with no response. Says the discount code has expired…Been doing this for several days.
    1. Hi Susan, please try the extension coupon to receive the discount: PRESALETSEXT.
  42. Hi! Today on 5/30 I tried to get the Pro Pack for the special discount price. But it says ‘This coupon has expired’. According to the newsletter the price should be valid until May 30th. Seems ‘until’ didn’t include May 30th.
    1. Hello! So sorry about that! Please enjoy coupon code PRESALETSEXT for the same great deal.
  43. I’m a long time Topaz user. I downloaded Topaz Studio and also bought the Pro Pack. I really enjoy using it. However, I just watched a you tube video by Heath Robinson at: https://www.youtube.com/watch?v=P7A5aDTqLn0. On one hand its very comprehensive, but on the other hand it moves so very fast, its hard to follow everything. I hope you’ll be creating other you tube tutorials that go a little slower!!!! Thanks!!!!
    1. Good morning, Charles! Glad you liked the overview video. We will definitely be making more educational resources including videos, webinars, and blog posts.
  44. I was really interested in the Topaz Studio, but where is the coupon code to purchase it?
    It’s too late now. You don’t make it easy. And it is frustrating to get an invite to purchase, but no coupon code. When you click on the Presale link all you get is ads for another package.
    1. Hi John! Sorry about the frustration. Please enjoy the discount with coupon code PRESALETSEXT. Have a great day!
  45. Is it too late to purchase the Pro Pack for $70? I have entered the coupon code PRESALETEXT but the total is still $99. Thanks for your assistance.
    1. Hello! Please use coupon code PRESALETSEXT. (There was a small typo in the coupon code you provided.) Hope this helps!
  46. Have downloaded the studio software with the pro pack. All works well so far but only as a stand-alone. It is a no-show in the Topaz filters list in PhotoShop. Me or you?
    1. Hi Jack! I am sorry that you are having issues with Topaz Studio. Please open a support ticket at help.topazlabs.com.
  47. Hi, I have purchased studio. After downloading it, I followed my usual procedure, which is to copy the program onto a usb pendrive and then attempted to load it onto my pc which is in a place without wifi (as I have done with my other Topaz plugins). I cannot load the programme as it tells me I need a wifi connection to do so. So how do I work ‘off the grid’. I am not sure what ‘sync your purchases’ means when I cannot connect to the web!
    Work off the Grid
    As photographers, we know sometime your work takes you off the beaten path. Use Topaz Studio while you’re on the move. Once you’ve synced your purchases you’ll have access to your Topaz Studio tools even without an internet connection.
    What does this mean to people working without wifi. Do I have to connect to the web every so often to continue using studio?
    Thanks Pete
    1. Pete,
      You’ll need to have the computer that you’re installing studio on connected to the internet during the initial install and when you first sign in so that it can authenticate your account. After thet you’ll only need to connect every 60 days to update and reauthenticate. Just moving the installer file to a thumbdrive won’t work, because the installer downloads files from the internet during the installation process. So you’ll have to be connected initially on the machine you want to install Topaz Studio on.
  48. Hi Jodi, I’m having trouble working out how to change the Workspace configuration. I noticed in one Topaz video that the adjustment tools were listed horizontally in the right hand column and that the presets were at the top of the screen. Also, where do I find tools like spot removal or cloning brushes?
    1. Hi Keith! The tools in that location is from an older version of Topaz Studio. Sorry about any confusion! We are currently working on adding new tools. Stay tuned for more updates!
  49. I have all of the Topaz plugins with the latest version updates. I got the free version of Topaz Studio but there is no button to go to the plugins on the home screen of Topaz Studio. I know you need the latest version of the plugins but I have that. How can I get the plugins to show up in Topaz Studio?
    1. Hello Nancy! You can access your Topaz Labs plugins in Topaz Studio by going up to the Menu Bar (very top of your screen) and then select Plugins. A drop down menu will show all your available plugins. If you are having difficulties, please open a support ticket: help.topazlabs.com
  50. I just downloaded topaz studio and purchased the pro pack but I thought it was going to be a plug in for my ps c.f. but it is working as a stand alone editor , how do I fix this?
    1. Topaz Studio is a plugin for PS and LR, a standalone, and a host editor. You should be able to access it through your Plugin Menu in PS. If you are unhappy with your purchase or need assistance, please submit a ticket: help.topazlabs.com. Have a great day!
  51. Hello. It seems as though you have a lot of technical questions. I suggest opening a ticket at help.topazlabs.com so that we may answer all your questions and help you further.
  52. I purchased the Studio Pro Pack but I already had all the previous plugins. I’m not sure what I bought. What does Studio and the Pro pack do for me that I couldn’t do before? It’s not clear to me what Topaz Studio is or why I need it since I use a LR and PS workflow. In other words, what is the advantage to using Studio within a PS layered workflow? What have I gained?
    1. Topaz Studio is a simple to use editing platform with Topaz Labs’ powerful acclaimed photo enhancement technology. It works as a standalone editor, a plugin within Lightroom and Photoshop, as well as a host application for your other Topaz plugins. The Adjustment Pro Pack gives you access to all 24 adjustments. If you’d like to learn more about Topaz Studio, please visit: topazlabs.com. Click Adjustments in the drop down menu and select the Adjustment you’d like to learn more about!
  53. Hi, I never received the email about the introductory price of $70. Just saw this as i was trying to see which plug in I had already bought. Would be interested in knowing the code to add to my cart. Thanks, Susan
    1. Hi Susan, I show you are signed up to receive our emails. Please make sure you check all your folders (including spam for outlook or gmail) and mark as “inbox” or “not spam”. Thanks!
  54. I have been using Studio for a couple of days on my MAC and all of a sudden it ask for user name and password . I enter both but the program hangs and I can’t get logged in. I have completely recovered and reinstalled a couple of times with no luck. I downloaded and installed the program on my MacBook Pro with no issues. HELP
    1. Hello! Please open a support ticket at help.topazlabs.com so that we can assist you in fixing this problem.
  55. je suis Ă©merveillĂ© par la simplicitĂ© , la rapiditĂ© , la stabilitĂ© , de votre produit une vraie merveille je me rĂ©gale , dehaze , precision contraste , radiance , smudge …..quel rĂ©gal, je vous fais une publicitĂ© monstre dans mon club photo le meilleur de tous les plugs-in de photoshop et de loin bravo , bravo , bravo Ă  l’Ă©quipe topaz
  56. What is the logic behind having to create an account and log in to use Studio? Have to “authenticate” every 60 days? Why? If I pay for a “module” why do I have to share with you every time I launch and use the app? Studio is not then really “free” is it? You want access to my machine and my information. What other data are you pulling down and why? Security and privacy are very real concerns.
    1. Hello Abby,
      The login and sign in process replaces the license key system that we had before and the need to get a separate key for each adjustment, now when you log in, your purchases are automatically synced through your account. We also use the internet to sync custom adjustments shared through Studio, sync and backup your custom created adjustments to your account and provide update notifications, and other notifications directly through the interface. It also allows you to update the application directly through the help menu instead of having to download and run a new installer each time you’d like to update.
      We’re not getting access to “your machine and your information” although we do collect usage data from our users it is Anonymous and is assigned a random number to associate with your machine, it tracks how often you open Studio, and the different modules that you use while you’re in the program, as well as tracking what might have caused an error in the application if you encounter one. You have the option to opt out of the usage tracking at any time in the preferences by unchecking the “enable anonymous usage tracking” item in the Preferences menu.
      All information collected is securely encrypted, anonymous, and protected. We use this to generate usage numbers, see what effects and adjustments are most popular, and what features are being used the most, all in an effort to improve the software.
  57. I, too, would like to press for a user guide. The video tutorials are very good, but don’t replace a user guide. Current example: I have prepared a custom effect for 1 of a series of panorama photos. I now need to apply the effect to the rest of the series. The obvious way would be to batch process them, but I can’t see how to do this. I’ve looked in the blog, the forum etc and I can find no reference to batch processing. Does this mean Studio doesn’t support batching, or is it simply hidden somewhere where I can’t find it. This sort of question comes up frequently and the answer should be easy to find, but it’s not. Please, either a user guide or a LOT more of the specific tutorials (inluding batch processing if it exists ).
    thanks
    1. Hello Graeme,
      We’re working on finalizing a few structural things with the interface, responding to user feedback before we complete the user guide, the current version doesn’t support batch processing but it is on our feature list to include in a future update.
  58. cannot access Topaz Studio from Lightroom only from Photoshop can you help me?
    I have downloaded it but don’t see it from Lightroom as an option
  59. I have some of the Topaz plugins and love them, but what I dont like is the Topaz Studio will not let me register at all, so not good really.
    1. Hey David,
      I can see you have an account with this email. If you’d like to reset your password you can do so here: https://topazlabs.com/my-account/lost-password/
  60. I have always been “babied” by Lightroom. Can I use Topaz Labs as a stand-alone application? If so, where do I download my images from my camera?
    1. Hey Nicholaas,
      The studio isn’t actually an image importer or digital asset manager. If you’d like to import images you can do that via the file browser, or continue to use Lightroom, bridge, etc.
Leave a Reply
Your email address will not be published. Required fields are marked *
You'll receive your trial download and account through email.
