Topaz Star Effects
Create beautiful star and lighting effects
A plugin compatible with:
Topaz Star Effects
Topaz Star Effects
Topaz Star Effects
Topaz Star Effects
Create beautifully-rendered and natural lighting effects in seconds.
There are some photos with powerful elements that grab your attention. You almost can’t look away. A great way to achieve this in your own work is to add light effects that naturally accentuate your photo, like light rays, lens flares, and sun beams. We specifically designed this product to make this process easy. Star Effects includes everything you need to create natural and compelling lighting effects that will make your photos shine.
Great Lighting Effect
Choose from a variety of beautiful star effects like traditional, starburst, cross, hollywood, and more.
Auto-Detect Light Sources
Use a single click to apply your lighting effect at exactly the right place in your photo.
Completely Customizable
Adjust any part of the light effect that you can think of, and never create the same effect twice.
Light is everywhere. Accentuate a mild glow, create a powerful sun flare, or do anything in between. Use Star Effects and your creativity to make your great photos even better.
ex_sun02-after
ex_diamonds02-after
ex_xmas02-after
ex_forest02-after
Topaz Star Effects
Not every image needs star or lighting effects, but the ones that do will look absolutely amazing with them. Use Topaz Star Effects to create one-of-a-kind photos that no one will be able to look away from.
Star Effects requires a compatible host program in Mac OSX 10.6+ or Windows 7+ with 4GB RAM or more.
You'll receive your trial download and account through email.
